Old August 22nd, 2014, 4:06 PM
subscession subscession is offline
subscession is on a distinguished road
Port Plug
I lost the port plug that came with my VTF-2 MK1 and am now using a nerf ball in one port to run in extension mode.
Is the original port plug designed specifically for each sub/port such that how deep the plug goes down the port could affect bass response?
The 4-inch-across ball that I'm using sticks out from the side of the enclosure about an inch after i scrunch it in.
Could this solution have an adverse effect on the sound, or am I over thinking it?
Old August 22nd, 2014, 8:11 PM
As long as the seal is airtight, it will work fine. Make sure there is no air leakage in the seal, although even if there is a little it probably wouldn't be noticeable.
Old August 25th, 2014, 9:33 AM
+1. nerf ball is a new one on me!
Old August 29th, 2014, 4:15 PM
Thanks! I figured as much, but you never know.
Happy Labor Day Weekend fellow bass heads!
