Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old June 7th, 2004, 1:07 PM
dmass dmass is offline
dmass is on a distinguished road
Question Is a 100hz cross over freq too high?
My HT receiver has limited options for cross over settings. Lowest setting is 100Hz.
I have bookshelf speakers on my fronts that respond well down to 45-50hz.
I can send bass to both fronts and LFE or only to LFE. But cross over is 100Hz (or higher).
Will the 1220's work well (or as well as any sub) when crossed over at 100Hz+?
Old June 7th, 2004, 7:06 PM
Ddavidson Ddavidson is offline
Ddavidson will become famous soon enoughDdavidson will become famous soon enough
The 1220 will work excellent, even at much higher crossover points. Its mainly because its frequency response is very flat (+/-1dB), so it blends in nicely (as long as its well positioned). Case in point is the many Maggie owners running them up at 150-155Hz with little problem but initial positioning. When I use my 1220 (depending on which system its in) I normally crossover around 120Hz with great result. Its even easier than my Vtf's to make disappear within the soundstage.
Ddavidson
Old June 7th, 2004, 7:48 PM
Lwang Lwang is offline
Lwang will become famous soon enoughLwang will become famous soon enough
You should be able to use the 100hz crossover, given that you place the sub near center so that you don't start localizing it being in some off-center location. The 1220 is remarkably colorless. I've played music through various subs with the xo completely disabled. It's midrage is quite clear, sounding like a speaker with burned out tweeter. This is as opposed to other subs whose midrange sounds absolutely colored.
