Witch WSU sub?
My system isn't the top of the line, but I would like to have the best sound (bass), I can get for know. Used for home theater and music (more music). Currently system is:
Onkyo TXSR 506 Monitor 50's-fronts CS2-center TSI 100-backs PSW10-sub The sub will be switched out first. Room size is 15'x15'. Looking for advice on witch sub? Would like to have BIG bass for music and home theater. Thanks for any and all advice. |
I believe the ULS-15 is the sub of choice for the witches of the world.
http://www.weathervanesculpture.com/...s/wv_witch.jpg |
Sorry man, that witch is to rich for my blood............
My living room is 15x15 and opens into the kitchen which is 15x20 and the 3.3 works pretty well in there. I would love to have another 3.3 but everyone who hears it says "man you don't need any more bass."
Go with the 3.3 + turbo...........if you must have B A S S .........Actually I listen to music only with my 2.3+turbo and it is fills my every need for bass{I'm bass player}.
Phatster and nottaway. Thanks for the advice. Not sure what the 3.3 is. Maybe the VTF-3 MK3? Thanks.
Spudnick,
Assuming you have 8' ceilings in your 15x15 room I'd think the VTF2-MK3 would be a good choice for you. If you really need to go deeper than 18Hz then go with the VTF3-MK3 with Turbo but that's a lot of output for your room size. Then again, you can never have too much bass. I have a 2.3 running in max extension mode and it works very well for me in my 14'x18' ft room. Ken |
+1 what kmitchell said,get the 2.3 and add the turbo later.....that's what I did! Good luck!
Hi spudnick,
What high are your ceilings? Does your room open to any other areas of the house, and if so, what are the dimensions of those areas? Do you have any particular budget in mind for subwoofer? Thanks!
Pete - Hsu Research |
Hey Pete, Merry Christmas. The ceilings are 8'. I have 2 doorways from the room. One to the kitchen and the other to a hallway. Budget, is what the wife will let me get away with. For the sub, 300-500ish. If its totally kick ass, I would sell some of my other toys. Also, will my Onkyo TXSR 506 be enough for a bigger sub our will I need a extra amp? Thanks.......
There was 1 other thing that could be important. The room has all hard wood floors. Would this change anything?
__| |________| |__
__________________ Sorry about the poor diagram. Computer graphic artist I am not. Spudnick is my FIL and Im helping him dial in his home theater. the room is a basic square about 15x15x8. the two doorways are standard size and always open. One on the left is a hallway. One on the right is the kitchen which is narrow, similar to the hallway. The sub will be placed against the middle wall somewhere between the doorways. Corner or nearfield placement is not an option. Hardwood floors all around (will place a carpet pad under any bottom-firing sub). He's not in need of anything sub 20hz. Just clean bass for music and movies thatll rumble when needed. Listens to rock, no rap. With that room size, I thought the STF-2 would do well with a quicker response for rock music but still the ability to rattle the wife's teacups in the cabinet. Pete or anyone else, thoughts? |
Thanks for the info, spudnik and dafeist!
I suppose that you can get by with a 10" subwoofer... Using that Onkyo receiver would be just fine! I take it that your subwoofer will have to be placed in between the left and right main speakers, correct? Do you have space to eventually add a second identical true subwoofer? Thanks, and Merry Christmas! Sincerely,
Pete - Hsu Research Last edited by Pete_Hsu : December 25th, 2008 at 11:36 AM. |
Thanks Pete for your assistance. The stereo is against the wall between the 2 door ways (dafeist diagram). Sub is next to left speaker. Maybe able to move sub against left wall but would require a little innovation as said before, all hard wood floors and a door way. The simplest would be run sub or subs next to stereo (facing listener) but probably not the most ideal. The other thing would be run power lines under house to get to back of room. For the right sound, i would consider this and a second sub. Thanks.
Thanks spudnik, have a Very Happy New Year!
So Pete, what is your suggestion to my previous post? Spud.
spud, I would just try to keep it as far from the openings as possible. But if it has to be closer to one opening or the other, it's better to keep the sub closer to the left side, since the opening is only to a hallway.
So, should I go with the STF2 or the VTF2 MK3? Would the 2.3 be a better choice for music? How would the 2.3 compare to a Polk DSW500? Spud.
As I stated previously you can get by with the 2.3,if you are lacking LOW notes add the turbo.....Pete indicated the turbos are almost gone......My room is about third bigger than yours!
Hi Spud,
We've been giving you advise on subs based on performance but it sounds like you have some physical constraints to work with. I have to tell you that Pete is always a nice guy so when he says "I suppose you can get by with a 10" subwoofer..." he really means you should consider something a bit bigger for your room size and layout. The thing you need to consider about the VTF2.3 is the fact that it is "pretty big" (check the dimensions compared to the STF-2) so it may not fit well along side your mains. You mentioned that you could run power lines under the house but if you have an outlet on one of the back walls all you need to run is the signal coax between the Onkyo and the subwoofer. As far as comparing subs I think the STF-2 is more comparable to the DSW500. In my opinion the VTF2.3 would blow away the DSW500. Hope this helps, Ken |
OK, I just got wiring his 5.1 system tonight and ran the Audisey program from his onkyo. Made sure his dvd output DD, made sure the onkyo was playing DD and put in Dark Knight. From the first scene it was apparent that the little Polk 10 wasnt going to get the job done. I hadnt even bumped it 3 db's hot like I normally do and it was already port chuffing.
I think a 2.3 may be showing up in the future...
Panasonic Th-58PZ800U (TV) Carver AV-705x (5 channel amp) Pioneer VSX-1018 (AVR but used only as pre/pro) Sony PS3 (bluray and music server) Energy Veritas (all the way around) HSU VTF-3 HO w/turbo |
