Thread Tools Rating: Thread Rating: 24 votes, 5.00 average. Display Modes
Old June 6th, 2004, 9:30 PM
ropara ropara is offline
ropara is on a distinguished road
Question Does a throw rug "muffle" any sound output?
Using a throw rug underneath the subs seem to be recommended when placed on a hardwood floor - to minimize vibration.
Does it in any way impact the sound output ? Is there any impact from the "thickness" of the throw rug used ?
Old June 6th, 2004, 9:47 PM
A thick rug should not hurt the sound impact. Make sure it is not so thick that it touches the woofer though.
Old June 7th, 2004, 7:55 PM
Ddavidson Ddavidson is offline
Ddavidson will become famous soon enoughDdavidson will become famous soon enough
There is a lot of misunderstanding about this because of incorrect internet information. The size of a low bass wave means it can not be absorbed by carpet. Its mostly for decoupling the subwoofer from the floor, however there are people who may have such thick carpet that may interferes with the drivers travel and clearance spec. That in most cases is an extreme case.
The decoupling the spikes/feet prevents any spurious vibratory noises that may occur. You could also use soft rubber chair stops or felt pads under each foot/spike.
Ddavidson
Old June 8th, 2004, 3:34 PM
The throw rug over hardwood is advised for several reasons.
1) Stability: if part of the floor is uneven, this can prevent unwanted buzzing
2) Acoustics: Dr. Hsu says that it improves acoustics--for the same reasons you would use Sonex or sound absorbing foam.
3) Protection: the rug protects the floor, which is also very useful if you want to slide the subwoofer to another position
4) Decoration: you can match the throw rug color to nearby objects.
Will the rug muffle the sound? Well, bass acoustics are very unusual and counterintuitive. Bass is only stopped by dense things like sand, solid wood, or gas filled membranes. Throw rugs have nowhere near the depth to absorb any sound the subwoofer produces.
Basically, the bass goes through the rug, hits the floor, and spreads in every direction inside the room. It is omnidirectional--it goes in every direction even though there is a rug underneath.
Old July 13th, 2007, 11:43 AM
Mutnat Mutnat is offline
Mutnat is on a distinguished road
A buddy of mine with an STF-3 MK2 and myself with my VTF-3 MK2 both just picked up a Gramma from Auralex to put under our subs and we're both pretty happy with the results. It's also 23" x 15", which is the perfect size for both of our subs.
Old July 18th, 2012, 1:34 AM
EfrainCase EfrainCase is offline
EfrainCase is on a distinguished road
Recommend you pretty little liars season 2 dvd boxset,a very good-looking DVD!
Old March 6th, 2013, 2:03 PM
TheNit TheNit is offline
TheNit is on a distinguished road
I'm sure this may be obvious, but should a carpet be used on a tile (terracotta) floor as well?
Old May 8th, 2013, 12:24 AM
Hi TheNit,
Sorry if this is kind of late, but I would say yes to using a rug for terracotta tile floor as well.
Copyright ©2000 - 2023, Jelsoft Enterprises Ltd.
