Old November 11th, 2011, 7:13 AM
elwaylite elwaylite is offline
elwaylite is on a distinguished road
BAS CD Test Tone Results, Opinions Welcome!
Ive highlighted the modes I think I'll stick with, just looking at the results. Measured from center position, after audyssey setup and all of that. CD was played in Oppo 93.
Old November 11th, 2011, 8:02 AM
Sputter Sputter is offline
Sputter is on a distinguished road
Interesting man, what did you use to measure with? Your Q numbers are similar to my REW graphs. What db level did you run the test with and from what distance?
Did you try sealed?
Here is a graph with my dual 15Hs in a 4500^ room.
I used my SMS-1 to kill two peaks 50hz~.
One port open, EQ2, Q.7
I didn't keep my 95db graph (that's as loud as I've run my sweeps) but it's as a flat as my 75/85 sweeps.
Old November 11th, 2011, 8:08 AM
As far as dB level, I just set the Marantz AVR at 0.0 dB (reference), I was about 10ft from the sub in my listening position. Used a Radio Shack Analog SPL meter.
Old November 11th, 2011, 8:19 AM
So 75db is your reference lvl? (going by your numbers) Nicely layed out graph.
Old November 11th, 2011, 8:23 AM
Yeah, I would assume its 75dB.
Looking at the charts on HSU for the VTF-15,
0.7 one port EQ1 is pretty flat from 200 down to 20, then slopes to 15. 0.7 EQ2 is also flat from 200 to 25, and the midbass area is a little louder.
The midbass on the Max Ext mode is not that much lower, and I gotta think having the ability to get that extra sound/feel from 16-25 is important too.
I think Im gonna stick with 1 port open, EQ1, and 0.7. Im no subwoofer expert at all
Old November 11th, 2011, 8:34 AM
Here's a graph showing EQ1
Keep in mind that the meter isn't too accurate the lower you measure.
Note the hump ~16hz due to the boost from eq1
Old November 11th, 2011, 9:00 AM
Just looking at my data, do you think Eq1 Port 1 Q 0.7 is the right choice?
Old November 11th, 2011, 9:36 AM
Just looking at your numbers you're down 18db at 16hz from 50hz.
That's a huge drop. I would look for a better placement first. (if it was me)
Old November 11th, 2011, 9:48 AM
Im kinda stuck there, WAF.
Here is my room layout and chart of modes, about 10 feet from sub
Old November 11th, 2011, 9:54 AM
Once charted,
EQ1 Port 1 50 to 20hz is a 18db drop
EQ2 Port 1 is a 24db drop
EQ2 2 ports open is 20db drop
Once looking at the chart, Im starting to think Pete had a good suggestion in that 2 ports open mode is not too bad either. It'd dB's are higher from like 125 down to 22.5
Old November 11th, 2011, 10:23 AM
Q Chart
Old November 11th, 2011, 11:16 AM
Hey Jason,
Did you add the compensation factors to account for the inaccuracy of the SPL meter at the lowest frequencies? If not, then you need to add 2dB @ 31.5Hz, 4dB @ 25Hz, 7dB @ 20Hz, and 12dB @ 16Hz to the numbers you see from the SPL meter.
Old November 11th, 2011, 11:34 AM
Thanks Pete, that makes the charts results a lot better.
Old November 11th, 2011, 1:01 PM
Is there a corner you can use on outside of your mains (L or R) to take advantage of some room gain?
