Old April 20th, 2010, 4:06 PM
abc abc is offline
abc is on a distinguished road
What do you use to draw the room layouts?
Hi, I'm going to spend most of my time taking measurements of my room, which are sun room, living room, dining room, kitchen that are all open to each other... the only constant is the floor-to-ceiling height of 9 feet. I'm not looking then, for anything fancy app-wise, just something that can allow me to most quickly put down my rooms, objects, and measurements, and post it up so someone could kindly 1. recommend what Hsu sub would be 'big enough' and 2. possible sub placement. So, what's a good quick sketch software that would allow me to cut/paste onto a thread here, folks?
Old April 20th, 2010, 4:21 PM
Hi abc,
Nothing fancy needed, one can even do something quick in MS Paint and save as a *.jpg file to attach here at the forum. Alternatively, you can fax a drawing to us at 1-714-666-9261 , and include your email address so that we can respond via email.
Old April 20th, 2010, 4:51 PM
abc abc is offline
ah, faxing sounds like a great idea, thank you... I'll work on that!
Old April 21st, 2010, 11:34 AM
Thanks abc!
Old April 21st, 2010, 2:53 PM
abc abc is offline
Update: just faxed something over, it also has my email address. Pls let me know if anything cannot be made out, thankyou again.
Old April 21st, 2010, 3:56 PM
Hi abc, I did send an email response a little while ago, hopefully you got that!
Old April 21st, 2010, 9:05 PM
Dragonfly Dragonfly is offline
Dragonfly is on a distinguished road
For future use: Gliffy.com has a great free room layout program on line.
Old April 25th, 2010, 6:38 AM
abc abc is offline
yo thanks dragonfly
Old May 12th, 2010, 12:39 PM
Tandrin Tandrin is offline
Tandrin is on a distinguished road
I just used Gliffy - it works great!!
