Old September 22nd, 2016, 8:31 AM
New Yorker New Yorker is offline
New Yorker is on a distinguished road
Worth raising center channel?
I have my HC-1 MK2 speaker inside my cabinet on the top shelf, so that it sits just below the top of the cabinet, on which sits my plasma TV (see pix). The HC-1 one has wedges beneath it so that it's tilted up as much as possible.
So… should I place the HC-1 on top of the cabinet, where the TV stand sits now? This would necessitate raising the TV 5", which would mean either placing it on a riser or mounting it directly on the wall.
I know the speaker would sound better, as its tweeter would be closer in height to those of the HB-1 mains. The downside to this would be:
a) monitor would no longer be at what many consider the perfect viewing height (eye at mid-screen when seated on the couch). I find that viewing height ideal, too.
b) have to buy/install monitor wall mount.
c) aesthetically (not a huge factor), the whole thing would look busier/more cumbersome/less elegant, something to consider in a small 1-bdrm apt.
So the question really is, would sound improvement offset the drawbacks. Thoughts?
(Incidentally, if anyone's curious, I have the HB-1s set up following the "1.0 / 1.26 / 1.60" distance suggestions in the owner's manual. Alas, the speakers are not centered on the rear wall; the left is where it should be, but the right is a good 8' from its sidewall - out of picture - and yes, this bothers me to no end. Hopefully, imaging is not being compromised too badly)
Old September 27th, 2016, 10:07 AM
Having the tweeter closer to ear height, though ideal, is not as big of an issue as the HB-1 Mk2's due to the vertical orientation of the MT design. So moving it up to the top shelf might not provide as much of a difference. I think you should be fine keeping it where it is. You can always temporarily move the TV out for a bit and place the HC-1 Mk2 there to see if it makes a big difference such that it warrants mounting the TV higher or not.
Old September 27th, 2016, 10:16 AM
Thanks, Kevin, temporarily moving the center speaker atop the shelf if a great idea. Duh! And it's good to know the difference in sound quality will probably be just incremental.
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
