Old January 1st, 2020, 7:48 PM
Rebelrevolver Rebelrevolver is offline
Rebelrevolver is on a distinguished road
Duel subs - STF-2
Hi all,
I currently own a STF2. I want to upgrade but was hoping to add a 2nd sub, but another STF2 is hard to come by especially in Canada. Suggestions on adding another sub, should I stay with 2 10's or can i add a 12" sub...let me know thoughts...
Old January 2nd, 2020, 3:46 PM
Hi there!
Generally, it's ideal to have two of the same performing subs as you know they a perfectly matched and you can maximize the potential out of both. However if that is not an option, then I would make sure that the second sub will match the performance of your first sub or play louder and cleaner. Adding a 12" should be fine. The main consideration is that the 10" won't play quite as loud or as clean as the 12", especially in the low bass, so that may end up bottlenecking how loud the 12" would play.
Old January 18th, 2020, 1:31 PM
Calypte Calypte is offline
Calypte is on a distinguished road
Does Hsu Research have any plans to make a subwoofer with -3 db (at least) response below 16 Hz?
Old January 20th, 2020, 2:21 PM
Hi Calypte,
Someone quoted your post and made a dedicated topic here:
http://forum.hsuresearch.com/showthread.php?t=96141
