Old March 19th, 2007, 10:05 AM
JasonF JasonF is offline
JasonF is on a distinguished road
Sub Recommendations for my HT
Hello All!
I am in the beginning stages of planning my HT. I am considering SVS, Hsu, or Axioms. I am here on your forum to receive suggestions solely for a Hsu solution.
Below I have done my best to describe all the necessary information (probably too much!) you may need in order to arrive at a suggestion. My HT will be used primarily for movie content, only using it for music listening around 15% of the time. I truly love the feeling of becoming enveloped in the movie experience…being able to feel as well as hear every detail. While on that topic, I am not trying to assemble to best and baddest system around. Gone are those days, unfortunately!
My HT will be located in my finished basement. The HT room will share open space with a kitchenette and our children’s playroom. The rest of the basement can be closed off by doors (I have omitted those rooms from the drawing). Floors will be carpeted, except for ceramic in the kitchenette. The ceiling will be acoustical ceiling panels, at around 88” in height. I know drop ceilings are not ideal for HT’s, but that’s what will be there.
The HT will consist of a front projector ceiling mounted and an acoustically transparent fixed screen (perhaps maybe a motorized one). The receiver will probably be a Denon 7.1. Any other suggestions on the receiver would be greatly appreciated. The screen will be AT, due to wanted more a of a theater experience, and because I really am lacking space on either side of the 92” 16.9 screen (86” wide with masking). For this reason, the LF and RF speakers will be located behind the screen as well. I could go with using stands/bookcase speakers and squeeze the LF and RF on either side of the screen, but I have three boys (ages 2, 4, 6) who will share the basement. They would certainly topple them right away. Putting them behind the screen protects them, in my opinion!
I am leaning towards only installing a 5.1 setup for my HT, for the below reasons…
  • All the HDTV broadcast material I receive from my cable provider is only in 5.1 anyway.
  • The room does not appear to be that large enough to justify the need for 4 surround sound speakers (unless in your opinion you feel it does)
  • Cost. If 2 surround sound speakers will suffice, I’d much rather devote the extra $’s to a better sub.
My seating will consist of a sectional sofa. My wife does not want theater seating, plus I lack the room for 2 rows. Surrounds can be placed on the rear wall or side walls (gray line is boxed out beam).
The HT main room is around 1750 cu/ft. However, I have been reading that one must consider the entire area for a subwoofer, especially if your HT opens to other rooms. With that being said, this number jumps to around 5200 cu/ft.
The purpose of this request is to not only get suggestions, but also suggest (if possible) locations for the sub. I would prefer to have the sub located directly under the projection screen or in the corner next to the built-in component rack; however there is space on either side of the sectional sofa. I plan on sitting at the end facing the screen.
Some other random thoughts/questions…
My projector screen will be around 27” from the floor. I would like the sub to be there, because I lot of what I’ve read indicates the sub should be located at the front, under the screen. Then again, I’ve read about the method of crawling around on your floor to find the best location as well.
Turbo option is out: not enough available height if sub is located center stage, and my wife would never go for it!
The main draw to the AT screen is to be able to place my center and LF/RF speakers behind the screen. This gives me more room on that wall for a larger screen…..and….protects 3 of my investments from my children. I’m a little worried since their playroom is down in the basement as well. That being said, I would really like to consider devising some way to hide/protect the sub in the same manner. I know that enclosing a sub into a cabinet can cause all types of issues, but I still would like to explore this as an option. I am a woodworker on the side, so can pretty much build anything to accommodate this. I was considering the VTF-3 HO for this. It is side firing, and rear-ported, right? By rotating it 90 degrees and placing it main center stage, this essentially makes the cabinet depth 17” deep. I can make some sort of base cabinet, the width of the screen and depth around 20”, sit the sub in there (on the floor), and use speaker cloth to hide it. Does anything jump out at you stating “Don’t do this!”.
Other than the VTF-3 HO (with or without the possible hidden idea), what would work for my size room? Is the VTF-3 HO sub overkill? Do I need a sub this large due to the open space? I want to enjoy the sound/feel from the sub, but I plan to do nothing for soundproofing to the upper level. Again, this is not a dedicated HT. Yes, I know….it will be heard upstairs, but I plan on watching moves to their full level on a set schedule (ok’d by wife). However, I cannot afford to break the china in the dining room (located directly above the HT)!
The idea of a sub mated with the MBM-12 module really intrigues me as well, so PLEASE try to sell me on that as well. I would also consider dual subs, however they would need to be at the $450-$550 amount to justify this.
Well, I’ve ranted enough. If I have left out anything that would help you arrive at a few possible suggestions for my HT, please let me know.
As far as what speakers I plan on using for the rest of the HT….I’m still uncertain. I am contemplating the SVS SCS-01M left/center/right and the Axiom QS4 or QS8 for the rears. I see that you make speakers as well…and would really like to take advantage of the package savings….but I’m not entirely sold on direct-firing rears. Also, in order to maximize space behind the AT screens, I need speakers that at not rear-ported: they will be mounted directly to the wall.
Thanks so much of any help you provide!!!
I have attached a layout of the basement, and current pics of the HT room if they help to visualize the space.
Jason Falejczyk
Frankfort, IL
Basement Layout
View of Front of Home Theater Area
View of Rear of Home Theater Area
Area for Screen and Built-in Component Rack
View to rest of basement
Old March 20th, 2007, 5:26 AM
sethhobrin sethhobrin is offline
sethhobrin is on a distinguished road
I can't believe nobody has touched this one yet. I would recommend you use the form on the website to directly contact Dr HSU with your questions as you will probably get a more technical explanation.
My quick recommendations are to put the HO in the front right corner wherever is convenient. I would corner load that puppy. I would also pick up the MBM and place that nearfield to your main sitting position either directly behind or to the side with the driver facing you. Also make sure you get the Y cable and set it up per the instructions(crossovers, etc).
As far as a a receiver goes. The absolute best future proof reciever right now is the Denon 2807. It has 2 HDMI with passthrough and is absolutely phenomenal. It also does not have any technical problems such as the LFE problems that the Pioneers have. You can also find it only from JR.com and ONECALL.com(fully authorized online retailers) for 930 including shipping. Just call them and tell them you heard you could get a Denon 2807 for 930 including shipping. They will give it to you. They do NOT advertise this price on their web sites. Its only for people "in the know."
Old March 20th, 2007, 6:48 AM
Hey Seth
Thanks for the replies and suggestion. By front right HO placement, I assume you meant front left. The front right is the stairwell.
Where is the MBM-12 driver? Is it on the side like the HO?
Denon 2807. Great call! I was reading through Denon's site last week, and that is the one I initially picked. There is some debate over at Circuit City that this unit is the same as the one they sell: AVR-987. I learned last year when I bought my Samsung DLP that CC gets different units than regular retailers. I'm wondering if the 987 is only sold at CC, and is inferior to the 2807.
I missed seeing the online form to fill out.
Jason
Old March 20th, 2007, 8:39 AM
Is there a possibility of leaving a space behind your L shaped sofa and place the sub(s) back there? A VTF-3 MK3 directly behind there will be wonderful. Fire the woofer directly into the back of the sofa. An alternative if you have not already bought your furniture is to get a sofa and a loveseat instead of an L shaped one. With that layout, get two VTF-3 MK3 and use both as end tables on the two sides of the sofa (sofa facing the screen). Budget-wise, a pair of MK3 is about the same as a HO plus a MBM-12.
Old March 20th, 2007, 9:01 AM
Thanks for the reply Dr. Hsu!
I'm not sure I would want the sectional (yes, we've already bought it) 18" away from the wall from the rear wall. The only way I could possibly swing this is by removing part of the wall. Take a look at the 2nd picture. You will see that I placed the rear wall around 13" away from the foundation wall, to clear to sewer pipe (didn't want a soffit). The three cutouts are for built-in cabinets. I have the same depth clearance of 13" at the floor. I would have to build an alcove at the floor, placing the sub in there sideways to have it fire into the rear of the sectional. It would still protrude around 6"...which is acceptable I guess.
Alternatively, take a look at the angled wall. The cleanout is located there, at around 30" high, so I have the same option there of building a low alcove for the sub as well. Again, I'm not sure how this would affect acoustics (and would it send vibrations through the walls), being stuffed into an alcove.
Now to be honest, I have a guy at my house right now doing the mudding. Both these options above means I take a step back to frame out the opening, drywall, and then mud. If having the sub upfront in the left corner would be almost as good as these solutions, I may consider it. Of course, I'm looking to you to give me the best solution, and then I may need to work back from that.
Thank you!
Jason
Old March 20th, 2007, 10:07 AM
Ok, scratch the idea of placing it inside the alcove directly on the rear wall: I have conduit running the length near the floor. An alcove still can be placed on that angled wall, though...if it would make that much of a difference with the sub behind the sofa.
Old March 20th, 2007, 7:35 PM
goshko65 goshko65 is offline
goshko65 is on a distinguished road
Denon 987
Regarding the Denon 987 and 2807, same cake, different frosting; I believe the 987 is classed as the "pro"version, which means black faceplate and that it is easily rack mountable. I have a 985, which was the rack mountable version of the 2805, and was advertised as the professional model on the Denon website-hope this explanation helps.
Old March 21st, 2007, 5:15 AM
Jason
Just make sure you check the prices. 2807 sells for 1200 in stores but you can get it for 930 including shipping from JR.com and ONECALL.com if you ASK. I don't think that is much more than the 987 model. ONECALL and JR are both denon authorized online resellers so you get the full warranty through them.
