Old August 14th, 2013, 8:13 PM
mentatgom mentatgom is offline
mentatgom is on a distinguished road
Post Where to put the Subwoofer?
Hey All,
Since I'm moving, figured I would give the forum suggestions a try with regard to speaker/sub-woofer placement before I move it. I have a VTF2 MK3. Attached is a diagram of the rooms and ceilings are 10 feet. Floor plan is completely open, no walls. I just highlighted in red the intended area of use. Thanks!
Old August 15th, 2013, 9:45 AM
Hi Mentatgom,
Thank you for the detailed layout and congrats on the new place! Is it possible to place the VTF-2 Mk3 in the corner between the two sofas (upper right hand corner of the living room diagram)? I would try placing the subwoofer there first and run the subwoofer in max output mode (2 ports open).
Kevin
Old August 15th, 2013, 3:26 PM
Yea, I can put it anywhere... so I'll try that suggestion as my initial position. Thanks Kevin; looks like I'll be spooling out the RCA cable!
