Need more Ooomph!
Need more thump, not sure if it is just bass greed but I'm not satisfied. I've a dedicated HT in the basement, 13'X32'X8'. I'm running 1 ULS15, an MBM, and 10 HB1MK2s + 1 HC1MK2.
Considering another 10 or 20 ULS15s or maybe ported subs to move more air. Also considering Buttkickers. Any opinions? All driven by an Onkyo TXNR807 equalized with Audyssey. Main listening position is centered 11' from the front, ULS is in the front left corner. and the MBM is 12' from the front behind the front row seating, on a riser with the 2nd row seating, on the right wall. Thanks in advance for any advice! |
Yeah, 20 additional ULSs ought to do the trick! But seriously, I would add maybe one or two more ULS subs. I would also try to move the MBM 12 as close to your listening position as possible.
Define what you mean by 'thump'. Thump to me is the kick drum in a drum kit, which is mid to upper bass in the overall scheme of things. The ULS-15s are great for subsonics, but a smaller driver would provide more impact in what I would call the 'thump' region. So it depends where in the spectrum you're lacking.
I would have gone with the VTF-15H in that size room especially since the OP wants tactical feel.
Could I add a VTF15 and be able to calibrate it with the ULS? Regarding my oomph and thump needs, I'm wanting both more bass drum and subsonic HT explosions. I think I'm getting pretty good performance out of my MBM, it sits close and seems to have plenty of headroom. Need more more sub 50hz. I have it all equalized pretty flat but would like to boost the low bass, when I do the ULS seems to strain, it's clapped a few times, to get what I want at studio reference levels- action movies and the organ music on the Hsu CD. I'm thinking simply, I just need to move more air.
One was not enough
got the second ULS15 a month or so ago and now I have more oomph. Conclusion, one ULS was entirely insufficient for the size and acoustics of my HT.
Good form.
Incidentally, I recently began experimenting with this business of decoupling my subs, and was amazed at the difference. The sub does not play any more clearly (obviously) but it resolves a timing issue of airborne waves reaching your ears faster/slower than those conducted through the floor. A decoupled sub seems quieter due to the removal of all the energy that was getting to you through the floor , but that is easily corrected with the volume knob. The benefit is that regular program material sounds the same, but with the gain turned up the amp really lets loose on the dynamic stuff, so now explosions and things of that nature really stand out. Warning: decoupling may not always be the best solution, I'm just saying I've had a positive result in my current listening space. |
