Old January 24th, 2018, 11:47 AM
acepaul acepaul is offline
acepaul is on a distinguished road
2 Subs - Different Settings??
I have been living with my 2 VTF-15H MK2's for a little while now and am in the process of upgrading main and surround speakers to the KEF Q series. Amp is a Denon 6200 which has 2 sub outputs. I do use miniDSP for both subs.
My questions:
- Has anybody played around with port, EQ and Q settings with two subs and ended up setting them each differently?
- Perhaps one set for punchy mid bass with another set for lower frequencies?
- Will different settings cause issues with overall performance in the room?
- And finally, for those of you running two of these subs, what is your favorite port, EQ and Q settings for home theater?
Old January 24th, 2018, 4:19 PM
You can certainly try different settings. I would say that most of the time, when I have integrated two subs, I end up setting them pretty much the same. Of course, I may have to make some modification to the controls for both subs to make sure that the response is maintaining linearity. For example, subs can generally reinforce easily in the deeper bass than the mid-bass and as a result, you get a nice boost in the deeper bass frequencies. So you would use the EQ or the Q control functions to tame that down a little. In terms of performance, whenever you start adjusting the port configuration/EQ/Q settings, you're not only changing the response, but you're also changing the performance characteristics, especially with the port configuration. What ends up happening is that you may end up bottlenecking your sub system due to the setting on one sub. However, to your point on mid-bass and deeper bass separation, that is the main reason why we came up with the MBM series (now the EQ 2 mode on the ULS-15 Mk2). That allows you to use the ULS-15 MK2 in the mid-bass module mode so it can handle those frequencies for you and you can run the sub along with that with the crossover set to around 40-50 Hz. So that is a valid way of running a two sub system.
